SOLVED FDIC Boost - Pots have no effect
nstoicu
I just built a FDIC Boost and when plugging it in I get bypass signal and signal when engaged but my knobs don't have any effect on the signal. Is this due to a soldering error as the signal can still go through and the effect isn't on top? Not sure how this works as there is no bypass on this circuit. Thanks!
I traced the circuit and I believe I have a faulty IC chip, the signal works right up to the IC sends to the output, i'll get another chip and see if that solves the problem.
