Flat Blade Solder Tip
DeadAirMD
Does anyone know where to get one of these Flat Blade Soldering Iron tips from? I think that's what they're called. I also think my soldering iron uses tips that are 900M-T, so the tip itself needs the inside to be open so I can slide it onto my soldering iron.
  • Like
Reactions: fig
I've never seen one in the standard Hakko tip style, only the hotswappable type with integrated heating element.
This is the one I use in my Pace station, but of course, you'd need the compatible Pace ADS200 station to use it.
Hakko makes one, but it's also for their hotswappable station.
A bit pricey but worth every penny. It can pull pots, toggle switches, pin headers, whatever.
Copper wire works too. 14 ga or so, form it around the pads, tack each pin on the far end, then the ones in the middle. Heat it with a hot broad tip and wait for gravity to work
