That will work, although there might be "carrier" bleed from the 555 when the pedal is bypassed since the Mute pin won't be connected.
If that is the case you can run a wire from the Mute pad of the PCB down to the bottom center lug of the 3PDT (just solder it right on top of the 3PDT board).
