Friedman Mini
Any possible to trace the SLO mini? What awesome work guys!!!
There is no real reason to do that as all of the MINI series there is just a preamp which are the pedals SLO, BE-OD, etc., and power section.
The SLO pedal is already available https://www.pedalpcb.com/product/pcb596/
I already did the power section from the BE MINI., so you're all set other than someone to draw up the schematic and if Robert wants to produce the power board, PCBs available from Pedal PCB. However, the request has been out there for months!
Likewise, these amps are loud, BUT there are Class D chips which can go 2x or 3x (50w or 100w) mono and really, this is where companies like boutique cut back on purpose and only offer lower wattage so you are not 100% happy with it and keep purchasing from them!!
What needs to be done is rev.2 ant take these amps to the next level....a more higher-powered chip, so you know you have plenty of power on-hand for any venue and then make the fx loop switchable, maybe even add a clean!
We need support to build that bridge unless doing it solo.
