Fume extractor
I use this for mycology, probably not appropriate for solder fumes! It has a hepa filter
That should be fine with a HEPA filter. Most important is that it draws the fumes away from you.
It looks like yours discharges out of the filter and draws in at the top. Most I have seen would draw in through the filter, but I'm sure you can situate it in a manner that keeps you from breathing the fumes.
Yea it's because it's for mushrooms to thrive ,,I think I will get a carbon filter type or even solder outside,
There's an interesting thread with a lot of ideas-
Carbon filter is a good idea. HEPAs are dope.
Nuthins gonna beat actually extracting fumes though. That is: transporting them outside, away from you.
yea i can drill a hole thru my wall in garage then tool for some kind of exhaust fan that's the easiest solution to remove fumes to outside
