Hello guys!
So i’ve built the Glory Hole, I ordered the kit from musikding.com.
First time it didnt work, i might have put in the ic the wrong way and also burnt one of the capacitors with my soldering iron. Then for the second time I’ve changed all the 100n and 10n capacitors, the IC and the switch. I know I should be audio probing but I don’t have the resistor for that.
Can sombody help me? I’ve reflown everything multiple times, checked for coninuity. When following the signal backwards, I’ve got strong buzz up until the Tone knob. Also the led works, bypass works, when I crank the volume on the amp I have a very quiet signal coming thru when engaged.
Thank in advance. I can do readings and better photos tomorrow.
