psychepool
hello.
I made Golden Falk (Colombo Plexi Breed).
I also made Marble Drive, which has almost the same circuit as Golden Falk, but I was very satisfied because it didn't feel like there was a filter somewhere unique to Marble Drive.
The only disappointment is that the Treble Volume low gain setting produces a muffled sound when the gain boost is applied.
This is noticeable in high-pitched strings.
I got a hint from the fact that if I increase the treble volume, these symptoms will disappear.
When I lowered the 330pF connected between Treble Volume Pot 2/3 to 100pF like the marble drive, the symptoms completely disappeared.
However, of course, when using 100pF, the sparkle of the low gain and the tightness of the high gain are reduced.
Others who have made it ask if there were any symptoms like this, and if there is a way to solve the problem while maintaining the 330pF value.
I tested it by slowly lowering the value at 330pF, and even if it is about 150pF, the symptom occurs, and a value lower than this does not make a meaningful difference compared to 100pF.
Bias trimmer adjustment had no effect on this symptom.
