Greengage whine
Unklejudy
I’ve built two Greengage overdrives. Both work fine and sound great, but there is a whine when I crank them up. This whine is also picked up by other pedals even when the Greenage is off(bypassed), but disappears when I disconnect the 9v from the Greengage. I suspect the charge pump as the first one I installed fried. Is this a common issue?
Also the volume is very loud, I only have it at 9oclock for just above unity.
Thanks for you reply. I’m not sure, one was from Musikding.de, but I don’t know where they get them from. What would be a better alternative?
I have built two of these and didn't experience any whine, I got my TC1044s from Mouser.
Can you post a Picture of your Mouser TC1044S.
Tayda sells the 7660SCPAZ also & it's cheaper.
I buy mine Locally.
I've built around 30+ pedals with 7660SCPAZ and never had a Fail.
..... If it aint broke, don't fix it!
I have studied your TC1044S, They look like genuine Microchip stock and should be Good.
May I ask if you accidently plugged 18v into the pedals, you mentioned frying one!
The other query i have is, are you running digital effects from the same supply with a Daisy chain connected to these TC1044S pedals.
Do you get a slightly audible thud thud thud thud coming from your Amps speaker when not playing.
I have experienced this issue as well I received mine from Mouser. I don't notice it in a live setting, but practicing it is a bit annoying I figured it was the TC1044S I have been told that you shouldn't socket them but I am not sure how true that is.
It seems to be with Tayda TC1044S but PedalPCB confirms that's what he uses & never had an Issue.
RCZ just confirmed his Tayda TC1044S was faulty.
Put a 7660SCPAZ in & solved his Issue.
Does yours TC1044S look exactly like this with the same Text?
I only believe in the Machine Sockets like this :
It was on a multi out isolated power supply, but I tried having it on its own supply (a EHX 9v), and also a 9v battery. No thud from the amp. No to 18v.
