Grounding the enclosure helps to eliminate noise and outside interference.
If you use metal 1/4" jacks your enclosure should already grounded (unless there is a thick layer of powdercoat insulating the jacks from the enclosure).
Top Quality Parts for Guitar Effects Pedals and DIY Music Devices. Knobs, Pots, Switches, Kits, LEDs, Enclosures, Jacks, Wire, Resistors, Capacitors, Semiconductors
Also ensure that you're not using insulated jacks (i.e., anything with plastic threading). You can ground those to the enclosure too, but it involves a few extra steps.
