Guvernator Build
I soldered a pair Of 3mm reds in last night… go figure. literally no difference in sound that I could hear.
Did you solder them in correctly? Do they light up when playing (at least in high gain settings)?
You have me second guessing now… I did clip the leads fairly short and soldered from the top… guess I’ll flip it over later today and crank the pedal up and see if they light up 😂… I’m 99.9% positive I had the anodes in the right spot.
Thank you... my struggles with art are real with art.. I have no originality most times...
I feel you. I think a basic template for Tayda and changing up the font is enough for most builds to look professional enough.
Some of the stuff around here is humbling.
I think you nailed it with the silver sparkle and font choice.
one led lights up when playing but the one on the left does not light at all.... I assume it is all working correctly because I measured voltage on both leds... so everything should be all good
