DGWVI
- Build Rating
- 5.00 star(s)
I couldn't decide which version I liked best between the standard and Albini spec, so I slapped em together with their gains set to max (sorta- there's a 10r resistor between lugs 2&3 to cut back on some extraneous noise), after a buffer (as is the correct way) with a blend control, master volume and expression input for the blend
The Albini side (low clang) is built according to the accepted values including a 2N404A and 2N3565, except I used d9ks for a bit more output volume
The Standard side (high clang) uses an MP20 and 2N3057, with d9ks
Gain and leakage fro the germs is written on the tops
The blend circuit is just the Splitt N Blend from Moonn, which works wonderfully
@steviejr92 peer pressured me into doing actual artwork, so I figured I'd use the Big Black album, Atomizer as an inspiration
1590BBS, everything but the footswitch and LED mounted up top
Video starts with the expression controlling the blend. It's fairly subtle but noticable especially when going for noisier sounds. My favorite setting is with the blend at 50/50, though- it gives that clanky clang, but still has the ragged saturation of the standard spec
Here's a shorter vid demonstrating Volume knob cleanup and switching to the neck single coil -
