Heat shrink tubing for AWG22?
I use 1.5mm for single solder joints and 3mm to capture two parallel wires (like from an LED). Two heatshrink tips:
1. Slip the heatshrink on before making the last solder joint. Been there, done that.
2. Make sure the solder joint is cool before you try to slip the heatshrink over the joint, otherwise it will start shrinking too soon.
I ended up buying both size (1.5mm & 3mm) before receiving all the answer and tips here. :)
Thank everybody for the endless knowledge sharing!
