Help with DIY bypass switch for Delta Lab ADM 256 and Rockman Sustainor/ chorus&echo
drgonzo1969
Greetings! I have a little switching project I was hoping to get some guidance on. I would like to build a pedal that will have 3 switches to bypass 3 different rack effects. I have a Rockman Sustainor, Rockman Chorus/echo, and a Delta Lab ADM 256. All 3 have outputs in the back for a bypass footswitch. I will post photos from the owner’s manual below. Can someone help me understand how to wire this up?
Sounds like you need a TRS cable, and to connect the tip and ring.
If you've got a TRS cable, you could plug it in and just make the connection on the loose end to verify it works. Easiest would be if you've got a stereo jack so you could connect the terminals on the jack, but you could also just do some janky tinfoil business on the bare end.
