michaeleschuler
I was assisting someone with replacement of a DPDT switch in a Wounded Paw Battering Ram overdrive/fuzz pedal (an old v 1.0 model). The replacement of the switch that actuates the fuzz circuit was trivial and the new switch works fine. I also applied Deoxit D5 to the jacks by spraying it on plugs and inserting them repeatedly, and I applied it to the pots I could access via their bottom vents, but there was some overspray.
After allowing it to dry for about 15 minutes I tested it, and it sounded fine initially (a minute or so), but then it developed a high-pitched whine when just the fuzz switch is actuated. This doesn't appear to be switch related; it appears even if I jumper around the switch. I tried reseating/swapping out the dual op amp IC, but no effect. I also tried blowing out the enclosure with canned air to see if something might be bridging a trace or component. The replacement didn't appear to disturb anything and I don't see any component issues but I can't access the trace side of the circuit board. The attached photo is post-replacement.
Any ideas for a solution or troubleshooting? Suggestions for a repair person in the Pacific Northwest to contact?
