High Pass / Low Pass Filter
I'd love a board with a simple High Pass and Low Pass filter. This could be used for tightening up low-end for distortion circuits or creating a "lo-fi" effect. Maybe splitting a signal into two different sets of bands (like the old clean low end / distorted high end for bass). All kinds of fun stuff.
You want a board with separate high and low pass filters?
There’s also this:
Pro-filter?
It’s somewhat close but it would be much more functional if there was a frequency knob for both. So you could set the width of the band that is passing through. For example maybe you want 100hz-6k. Or maybe you want 20hz-250hz. Like what would be used in a standard recording EQ.
Pedalblock tone control is essentially a Muff tone stack. Not relevant to the HPF or LPF I’m after for cleaning up my bass signal.
It’d be cool if the filters were offered separately in a form factor that fits 1590a, but can still be thrown together in a 1590b or 1590n
You could put 2 pedalblocks together in a 1590A. One set as a high pass filter and one as a low pass filter.
I guess, after monkeying with the corner freqs extensively.
There was an arguement, ehr… thread … on Talkbass about the differences between regular tone/EQ controls vs HPF & LPF — it was my understandin they’re different enough to warrant a distinction but I don’t know.
I just like building utility boxes and at the other end of the spectrum I like building bleep-bloop robot-fart boxes.
VFE standout if you can find the unobtanium c10k/c100k dual pots.
I finished building mine recently and it works well both for tightening up the tone and for the lofi effect. The cuts are very deep, and I can't get those sounds out of other EQs.
I also made the Ibanez Lofi you can get here. I like it in the FX Loop. It always has some filtering you can't dial out, but the Standout is a clean EQ with no added drive. I see some of the dual pots still available on their site. The Focus may be another version of the same basic design, and you can get that project at Madbean.
You could start by trying to tack a passive HPF to the input of whatever circuit and LPF to the output and see if you like how that sounds. Just splice them in between the PCB and the switch.
Does C1 in this case determine the maximum frequency in one direction or the other?
The capacitor and the resistor set the corner frequency of the filter; using a pot as a variable resistor allows you to change the value of the resistor, which makes the corner frequency adjustable (as that link you shared makes clear!).
This is radical!
