Hal Harvey
THERES JUST TOO MANY THINGS TO DO AND KIDS TO FEED. PRIORITIES MAN PRIORITIES!
Btw, all didn’t go well this time. Had some problems during a test play. Clean sound was amazing, but when driven with square wave not so. Overall volume was also reduced and rising preamp gain caused outputs partial/total cutoff and crackling note decay.
Schematic here, red marks most recent changes. It’s missing 1Kohm resistor between OT speaker out leads.
Haven’t dived into troubleshooting yet, but I’ll gather some thoughts here:
I really need an oscilloscope. Alixpress messed my order and never received one I ordered in june. Got money back, but didn’t place a new order… I’ll start with bias first.
- Bias was set hotter than before. Now over 60%, before it was way over under 40%, maybe even under 10%. Hard to say, I cannot recall pot setting. Could it be my output transformer is with low turns ratio and prefers super cold class B biasing? Or do non-isolated divided two sided bias circuit cross talk when bias set warm?
- Oscillation? Preamp grid resistors aren’t soldered near socket, but in input jacks with shielded wire leading to tube.
- Cutoff happening with gain. V2 and PI are missing input grid resistors. Blocking distortion somewhere before big bottles?
- Raising treble made note decay worse, bridging inputs brought more acceptable sound and cured note decay. HF Oscillation?
- Are my 2x15 speakers causing all this? Should test another cab before diving too deep.
- Maybe PI plate resistor balancing was bad choice? Is snubber cap necessary? Does MerlinB talk shit which I believed?
Not the issue you are seeing but 270R 1W screen resistors seem really really low for both value and rating, especially for EL34s.
I had a 1.5K 5w burn up in my GT120 (also a quad of EL34s). The EL34 is hard on those. I have a 10w set ready to replace them if it happens again.
I’d keep that snubber on the PI plates.
Dumble used a pot to balance the PI on the ODS. I bought a handful of balanced tubes for PIs… that said I don’t think that is your issue. do you have some extra tubes you can swap in? Or even try swapping positions.
I’d change your bias back down just as a sanity check. I don’t see a glaring issue with the bias circuit. I know the diode has some resistance, is that and main cap enough of a RC filter? Do you see any major ripple on your meter?
I would try a grid stopper on the stage prior to PI first. One change at time, and then test.
I have a cheap FNIRSI 1014D scope with a HV probe but my own ADHD has stopped me from ever trying it on amps lol.
