pricklyrobot
Finally finished up this guy. It’s an Aion Graviton board.
Generally, on all of my fuzz and distortion builds I do some kind of raptor. But for this one I though I should probably have the most metal
bird of them all, the avian abattoir-ist, the butcherbird himself: your very own Loggerhead Shrike!!!
www.allaboutbirds.org
I did this mod:
Just bypassing the distortion section so you can use the EQ by itself. Got the idea from this old thread:
I didn’t bother labeling the toggle, because I think its location makes its function intuitive.
Overall, this was a pretty straightforward build. No real difficulties. It fired up on the first try
Did the knobs down the side just for something a little visually different.
Soundwise, I’ve dialed in one or two sounds so far that don’t sound like every other distortion. It definitely does “chainsaw on the other end of a tinny old telephone”
Got some cool sounds running it into a Phase 90
Loggerhead Shrike Overview, All About Birds, Cornell Lab of Ornithology
The Loggerhead Shrike is a songbird with a raptor’s habits. A denizen of grasslands and other open habitats throughout much of North America, this masked black, white, and gray predator hunts from utility poles, fence posts and other conspicuous perches, preying on insects, birds, lizards, and...
I did this mod:
Hi everyone,
I have just got a Promethium distortion pcb in the mail, I've waited long enough for Boss to make a Waza HM2, so I'll just make one myself.
I was thinking of also making a tagboard HM2 EQ only for use with other distortions, or just for some 'HM2 flavor' without the clipping, but then I thought, shouldn't it be possible to just bypass the distortion section of the pedal with a SPST switch? I've (poorly) drawn over the schematic from the build docs in mspaint, just jumping from the input buffer to after all the clipping, would this work? Or do I need to use a larger switch...
- mnemonic
- Forum: Modifications
