I am not sure this is easy to do in general. There may be some pedals for which it’s easy to merge the controls (although I can’t really imagine what tone stack topology would let you do that, and how the merged controls would work) and others hard.
However I would recommend a different approach: move the less “useful” or interesting controls to a trim pot inside the pedal or replace them with a pair of resistors that you can socket and change later (depending on the topology, one resistor may be enough).
My first reaction was to put a BMP tone stack in there. I reread the question and now I have a question. Fully CCW it’s only bass and CW only treble and at noon it’s a mid hump? Sounds like you want a variable band pass filter
I'm trying to put two preamp pedals, a power amp pedal, a reverb pedal, and some other stuff into a chassis and hopefully make a two-channel combo amp. The chassis can't really fit a bunch of knobs from the pedals, so my main goal is to have less of them.
Thanks for this idea. I see that the M800 already has 6 trim pots inside of it, and one is labeled "tone" so that seems like something to check out. I was also considering using concentric pots to combine 2 knobs into 1, but it's hard to find them with values matching the build guide. Do pot values affect the sound a good amount?
I'm not really sure honestlyI read that a tone knob on a guitar was a low pass filter, but I don't know if it's the same on pedals/amps. I will look into the variable band pass
Take a look at the Tilt EQ format. That does about as much on one knob as anything I've seen. Not necessarily the greatest for midrange tweaking though.I'm not really sure honestlyI read that a tone knob on a guitar was a low pass filter, but I don't know if it's the same on pedals/amps. I will look into the variable band pass
