Tommygun011198
Hi all,
I just finished building my 1st FV-1 build - the hydra delay - and I’m struggling with a few issues.
All of the controls and delay heads of the pedal work and I followed the build documents without any modifications (until I switched it on and had some issues) but the problem I have is with the (1) volume control and (2) some background noise or a massively raised noise floor.
1. The volume issue is that the volume knob is extremely sensitive, and I can only turn it clockwise slightly before it exceeds unity volume. I thought this was the fault of the pot so I changed the linear b100k volume pot for a logarithmic a100k pot but the issue was the same. When the pot is fully counterclockwise there is no sound which I would expect from the volume knob, but as soon as it is turned up slightly the volume comes on, there seems to be no gradual ‘ramp’
2. The second issue is with the background noise when the pedal is active which is more than I would normally expect from a pedal.
All the ground pins of the fv1 are grounded as are the tl072 ground pins
I only started building pedals this year so please go easy on a rookie builder.
Any help would be hugely appreciated
Thank you
Tom
Thank you
Tom
