DailyDovetails
- Build Rating
- 5.00 star(s)
This pedal sounds pretty much how I expected it to. I think the only surprise is that the boost is actually a little better than I had expected not that I imagine the boost that much. I have wanted one of these probably since the early 2000's as a Stephen Carpenter fan. More recently I have really enjoyed this pedal as used by both Electric Wizard and Monolord.
The build on this was a little more demanding than I had imagined it would be. Not really difficult especially if you go slow and measure the parts as you install them but there are a ton of tiny 1/8 watt resistors and electrolytic capacitors on this board.
I feel like after working on the process for a while I have a pretty good 3D printable pedal platform. I posted all the files to build this here https://www.thingiverse.com/thing:6492607 in case anyone else wants to give it a try. The only part I don't think I have really hatched out yet is the power supply diameter, I'm thinking in the future I might make the power supply hole larger and then make adapters for the different sized DC adapters.
I put some pictures I normally wouldn't include for a reference of how everything goes together. If there is an interest I will consider putting together the files for other pedals.
