KR Sound Well-known member Today at 6:34 PM #1 Seems like I should know this. Is there anything making this circuit unable to swap the power jack? Or would I have to swap some cap orientations as well? Last edited: Today at 6:46 PM
Harry Klippton Well-known member Today at 6:51 PM #2 You have the pedal in front of you. Can't you trace it?
BuddytheReow Moderator Today at 8:16 PM #3 Do you still want to be able load a battery in there after swapping the power jack?
KR Sound Well-known member Today at 8:42 PM #4 BuddytheReow said: Do you still want to be able load a battery in there after swapping the power jack? Click to expand... Maybe, I’ll have to ask my friend. It should just be a matter of swapping out the jack and wiring it like normal. It’s been a long day and I’m overthinking this.
Robert Reverse Engineer Today at 9:02 PM #5 If the goal is just to simply replace the DC jack, then yes, you can just replace it directly with any typical three terminal DC jack. The pedal is positive tip / positive ground though. I assume your friend uses a special power supply with this one? Reckon you could get some good clear pics of both sides of the PCB in there? For you know... science...
