I think my Pro-10 Green and Noblemen are both possessed
BeeSharp
So, I've built a couple of the Aion Andromeda's before and one of those also had this possessed sound. I just finished a Nobleman and a Pro-10 Green - and they both have this possessed power supply sound. However, whenever I kick on another pedal (Tweedman in this case), the noise stops.
For reference, I had a simple boost pedal that was making a similar sound. In my case swapping IC's and transistors didn't help. The sound stayed the same when I unplugged guitar. I also cleaned up and checked the internal wiring and grounding, no change.
I "solved" it by powering it with a separate power supply from the other pedals. I'd be surprised if your nice Strymon power supply would cause it, but may help you troubleshoot. When time permits, I was going to swap out the power filtering caps on the boost pedal to see if that helps.
