Illuminated 3dpt breakout board.
chongmagic
I tried one of these out today. I assume that the CLR should be removed when using these in place of a regular LED? I am working on the Two Sticks of Derm and connected it but the LED on the footswitch won't illuminate. I did include all three 4k7 resistors. I'll try removing the CLR and see if that resolves the issue.
Check this thread
Yep, I need to make up a little one-page doc on using these.
They'll still use the on-board CLR, but you do need to install a jumper in the place of the LED on the main effect PCB in use.
