In search of Stereo Reverbs and Delays to fill 2 Binaura EEPROMS.
Not really responsive to the pot controls. are these supposed to be floating blocks?
Not at all. This is concerning. When I opened mine back up, it looked like yours too. On my MacBook I corrected, re-saved & re-opened it; only to have it with the dropped pot connections again. So, I started it over from scratch and did a "Save As..." with a new name: "R01_Stereo_Ambient_Reverb_02.spcdj" - and It's supposed to look like this (And note how the filename is not yet inserted into the first line of the patch's "Patch Information" dialog box. All the Control Panels were closed when I did the "Save As..."; then opened them all and took this screencap.) . . . .
But when I re-opened the new "R01_Stereo_Ambient_Reverb_02.spcdj" file, it opened up looking like this (And note how the 1st & 2nd lines of the patch's "Patch Information" dialog box are filled in now. That first two lines are NOT user editable - But the other lines below them are.) . . . .
So I'm off to my Windows machine to see what's different. I suspect it may have to do with the Java version on my Mac. I need to run some tests and debug mode captures for Digital Larry.
@BrainGutz, @Digital Larry - what happened as described in post #101, also happens in Windows. Suggesting something's not right about the "Reverb Designer" block. So I'm at a loss for now. The only work-around I can see right now is to save out the SpinASM file before saving the SpinCAD native patch when using this block. But I haven't tried that yet, but will tomorrow.
I'll also go back to the drawing board in an older version of SpinCAD (before the JSON file saving routines, and see what I can spin up for R01.
Yeah, that should get you there. You'll have to read the instructions for EEPROM burning/flashing, cuz I use a Spin-Semi FV-1 Development Board to flash mine. I only use my generic EEPROM flasher for reading/ripping. And note that this unit does not come with the software, but tells you where to find it.
Is the spin fv1 development board an appropriate tool for burning eeproms or just for testing sounds?
It does both. However, auditing from the Spin-Semi FV-1 Dev Brd lacks a Dry/Wet mix. The best auditing method is from an actual FV-1 corcuit build. I like how easily The SpinASM software writes to the Dev Brd. And if there's something wrong with the SpinASM file, the software tells you which patch and what line(s) is (are) offending it when you go to "Build" (flash) the EEPROM.
Ah! So do you keep the back loose or off of the pedal to access the board or do you just not need an enclosure? It seems like it would be annoying having to access the eeprom itself regularly.
I keep the backs loose of those pedal I need to access often; keeping the screws in. a small plastic baggy.
I should have the first reverb patch candidates later today. I'm frustrated about the Reverb Designer block issues.
Here are two candidates for R01 - High-Diffusion Ambient Cloud Reverb: Multi-tap delay network feeding an 8-stage comb/allpass matrix configured for high diffusion and seamless, blooming sustain.
R01_Stereo_Ambient Reverb_04.spcdj
JSON:
  "formatVersion": 1,
  "buildNumber": 1070,
  "type": "patch",
  "patchFileName": "R01_Stereo_Ambient Reverb_04.spcdj",
  "comments": {
    "fileName": "R01_Stereo_Ambient Reverb_04.spcdj",
    "version": "Patch saved from SpinCAD Designer version 1070",
    "lines": [
      "Pot 0: Reverb Time",
      "Pot 1: Feedback",
      "Pot 2: Comb Feedback",
      "Multi-tap delay network feeding an 8-stage comb/allpass matrix configured for hi diffusion & seamless, blooming sustain."
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "className": "com.holycityaudio.SpinCAD.CADBlocks.InputCADBlock",
      "blockNum": 0,
      "x": 324,
      "y": 11,
      "name": "Input"
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot0CADBlock",
      "blockNum": 1,
      "x": 8,
      "y": 96,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot1CADBlock",
      "blockNum": 2,
      "x": 6,
      "y": 135,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Pot2CADBlock",
      "blockNum": 3,
      "x": 6,
      "y": 198,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Mixer_2_to_1CADBlock",
      "blockNum": 4,
      "x": 266,
      "y": 75,
      "name": "Mixer 2:1",
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "className": "com.holycityaudio.SpinCAD.CADBlocks.FBOutputCADBlock",
      "blockNum": 5,
      "x": 418,
      "y": 63,
      "name": "FB Out 1",
      "params": {
        "register": 33
      "className": "com.holycityaudio.SpinCAD.CADBlocks.ScaleOffsetControlCADBlock",
      "blockNum": 6,
      "x": 66,
      "y": 97,
      "name": "Scale/Offset",
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.15,
        "outHigh": 1.0
      "blockNum": 7,
      "x": 63,
      "y": 198,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.04,
        "outHigh": 0.8
      "className": "com.holycityaudio.SpinCAD.CADBlocks.control_smootherCADBlock",
      "blockNum": 8,
      "x": 158,
      "y": 97,
      "name": "Smoother",
      "params": {
        "filtReg": 37,
        "filt": 1.9353341013150782E-4
      "className": "com.holycityaudio.SpinCAD.CADBlocks.eighttapCADBlock",
      "blockNum": 9,
      "x": 266,
      "y": 126,
      "name": "Eight Tap",
      "params": {
        "inputGain": 1.0,
        "fbkGain": 0.3981071705534972,
        "delayLength": 27853.0,
        "tap1Ratio": 0.125,
        "tap1Gain": 0.5,
        "tap2Ratio": 0.25,
        "tap2Gain": 0.5,
        "tap3Ratio": 0.375,
        "tap3Gain": 0.5,
        "tap4Ratio": 0.5,
        "tap4Gain": 0.5,
        "tap5Ratio": 0.625,
        "tap5Gain": 0.5,
        "tap6Ratio": 0.75,
        "tap6Gain": 0.5011872336272722,
        "tap7Ratio": 0.875,
        "tap7Gain": 0.5,
        "tap8Ratio": 1.0,
        "tap8Gain": 0.5,
        "delayOffset": -1.0,
        "mix1": 38,
        "mix2": 39,
        "max": 40,
        "tap8": 41
      "className": "com.holycityaudio.SpinCAD.CADBlocks.LPF_RDFXCADBlock",
      "blockNum": 10,
      "x": 407,
      "y": 351,
      "name": "LPF 1P",
      "params": {
        "freq": 0.20171035571672602,
        "lpf1": 42
      "className": "com.holycityaudio.SpinCAD.CADBlocks.CombFilterCADBlock",
      "blockNum": 11,
      "x": 407,
      "y": 220,
      "name": "Comb_Filter",
      "params": {
        "gain": 0.44668359215096315,
        "delayLength": 2171.0,
        "feedback": 0.69,
        "damping": 0.7,
        "output1": 43,
        "filtReg": 44
      "className": "com.holycityaudio.SpinCAD.CADBlocks.FBInputCADBlock",
      "blockNum": 12,
      "x": 407,
      "y": 403,
      "name": "FB In 1",
      "params": {
        "register": 33,
        "lGain": 1.0
      "blockNum": 13,
      "x": 242,
      "y": 238,
      "params": {
        "gain": 0.5,
        "delayLength": 2245.0,
        "feedback": 0.7,
        "damping": 0.5,
        "output1": 45,
        "filtReg": 46
      "blockNum": 14,
      "x": 407,
      "y": 273,
      "name": "LPF 1P",
      "params": {
        "freq": 0.18572835587626246,
        "lpf1": 47
      "blockNum": 15,
      "x": 242,
      "y": 289,
      "name": "LPF 1P",
      "params": {
        "freq": 0.15,
        "lpf1": 48
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Mixer_4_to_2CADBlock",
      "blockNum": 16,
      "x": 303,
      "y": 346,
      "name": "Mixer 4:2",
      "params": {
        "gain1": 1.0,
        "gain2": 0.12589254117941673,
        "gain3": 0.12589254117941673,
        "gain4": 1.0,
        "output1": 49,
        "output2": 50
      "className": "com.holycityaudio.SpinCAD.CADBlocks.OutputCADBlock",
      "blockNum": 17,
      "x": 303,
      "y": 402,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "fromBlockIndex": 0,
      "fromPin": "Output 1",
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "fromPin": "Output 2",
      "toBlockIndex": 4,
      "toPin": "Input 2"
      "fromBlockIndex": 1,
      "fromPin": "Control Output 1",
      "toBlockIndex": 6,
      "toPin": "Control Input 1"
      "fromBlockIndex": 3,
      "toBlockIndex": 7,
      "fromBlockIndex": 6,
      "toBlockIndex": 8,
      "toPin": "Control Input"
      "fromBlockIndex": 4,
      "fromPin": "Output",
      "toBlockIndex": 9,
      "toPin": "Input"
      "fromBlockIndex": 5,
      "fromPin": "Feedback Output",
      "toBlockIndex": 9,
      "toPin": "Feedback"
      "fromBlockIndex": 8,
      "fromPin": "Control Output",
      "toBlockIndex": 9,
      "toPin": "Delay Time 1"
      "fromBlockIndex": 2,
      "toBlockIndex": 9,
      "toPin": "Feedback Gain"
      "fromBlockIndex": 9,
      "fromPin": "Tap 8 Out",
      "toBlockIndex": 10,
      "toPin": "Input"
      "fromPin": "Mix 2 Out",
      "toBlockIndex": 11,
      "toPin": "Input"
      "fromBlockIndex": 7,
      "toBlockIndex": 11,
      "toPin": "Feedback"
      "fromBlockIndex": 10,
      "toBlockIndex": 12,
      "toPin": "Feedback Input"
      "fromPin": "Mix 1 Out",
      "toBlockIndex": 13,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Feedback"
      "fromBlockIndex": 11,
      "toBlockIndex": 14,
      "toPin": "Input"
      "fromBlockIndex": 13,
      "toBlockIndex": 15,
      "toPin": "Input"
      "fromBlockIndex": 15,
      "toBlockIndex": 16,
      "toPin": "Input 1a"
      "toBlockIndex": 16,
      "toPin": "Input 1b"
      "toBlockIndex": 16,
      "toPin": "Input 2a"
      "fromBlockIndex": 14,
      "toBlockIndex": 16,
      "toPin": "Input 2b"
      "fromBlockIndex": 16,
      "fromPin": "Output1",
      "toBlockIndex": 17,
      "toPin": "Input 1"
      "fromPin": "Output2",
      "toBlockIndex": 17,
      "toPin": "Input 2"
R01_Stereo_Ambient Reverb_05.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R01_Stereo_Ambient Reverb_05.spcdj",
  "comments": {
    "fileName": "R01_Stereo_Ambient Reverb_05.spcdj",
    "lines": [
      "Pot 1: Feedback",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 340,
      "y": 4,
      "name": "Input"
      "blockNum": 1,
      "x": 8,
      "y": 116,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 8,
      "y": 155,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 11,
      "y": 319,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 4,
      "x": 266,
      "y": 75,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 5,
      "x": 388,
      "y": 74,
      "name": "FB Out 1",
      "params": {
        "register": 33
      "blockNum": 6,
      "x": 66,
      "y": 117,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.15,
        "outHigh": 1.0
      "blockNum": 7,
      "x": 68,
      "y": 319,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.04,
        "outHigh": 0.8
      "blockNum": 8,
      "x": 158,
      "y": 117,
      "name": "Smoother",
      "params": {
        "filtReg": 37,
      "blockNum": 9,
      "x": 266,
      "y": 146,
      "params": {
        "inputGain": 1.0,
        "delayLength": 25283.0,
        "tap1Ratio": 0.125,
        "tap1Gain": 0.5,
        "tap2Ratio": 0.25,
        "tap2Gain": 0.5,
        "tap3Ratio": 0.375,
        "tap3Gain": 0.5,
        "tap4Ratio": 0.5,
        "tap4Gain": 0.5,
        "tap5Ratio": 0.625,
        "tap5Gain": 0.5,
        "tap6Ratio": 0.75,
        "tap7Ratio": 0.875,
        "tap7Gain": 0.5,
        "tap8Ratio": 1.0,
        "tap8Gain": 0.5,
        "mix1": 38,
        "mix2": 39,
        "max": 40,
        "tap8": 41
      "className": "com.holycityaudio.SpinCAD.CADBlocks.allpassCADBlock",
      "blockNum": 10,
      "x": 226,
      "y": 209,
      "name": "Allpass",
      "params": {
        "gain": 0.5,
        "nAPs": 4.0,
        "ap1length": 125.0,
        "ap2length": 250.0,
        "ap3length": 750.0,
        "ap4length": 1500.0,
        "kiap": 0.5,
        "output1": 42
      "blockNum": 11,
      "x": 286,
      "y": 210,
      "name": "Allpass",
      "params": {
        "gain": 0.5,
        "nAPs": 4.0,
        "ap1length": 125.0,
        "ap2length": 250.0,
        "ap3length": 750.0,
        "kiap": 0.5,
        "output1": 43
      "blockNum": 12,
      "x": 395,
      "y": 208,
      "name": "LPF 1P",
      "params": {
        "lpf1": 44
      "blockNum": 13,
      "x": 227,
      "y": 346,
      "params": {
        "gain": 0.5,
        "feedback": 0.7,
        "damping": 0.5,
        "output1": 45,
        "filtReg": 46
      "blockNum": 14,
      "x": 402,
      "y": 321,
      "params": {
        "feedback": 0.69,
        "damping": 0.7,
        "output1": 47,
        "filtReg": 48
      "blockNum": 15,
      "x": 227,
      "y": 397,
      "name": "LPF 1P",
      "params": {
        "freq": 0.15,
        "lpf1": 49
      "blockNum": 16,
      "x": 402,
      "y": 374,
      "name": "LPF 1P",
      "params": {
        "lpf1": 50
      "blockNum": 17,
      "x": 322,
      "y": 467,
      "params": {
        "gain1": 1.0,
        "gain4": 1.0,
        "output1": 51,
        "output2": 52
      "blockNum": 18,
      "x": 395,
      "y": 260,
      "name": "FB In 1",
      "params": {
        "register": 33,
        "lGain": 1.0
      "blockNum": 19,
      "x": 322,
      "y": 523,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "toBlockIndex": 4,
      "toPin": "Input 2"
      "toBlockIndex": 6,
      "toBlockIndex": 7,
      "toBlockIndex": 8,
      "toBlockIndex": 9,
      "toPin": "Input"
      "toBlockIndex": 9,
      "toPin": "Feedback"
      "toBlockIndex": 9,
      "toBlockIndex": 9,
      "toBlockIndex": 10,
      "toPin": "Input"
      "toBlockIndex": 11,
      "toPin": "Input"
      "toBlockIndex": 12,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Feedback"
      "toBlockIndex": 14,
      "toPin": "Input"
      "toBlockIndex": 14,
      "toPin": "Feedback"
      "toBlockIndex": 15,
      "toPin": "Input"
      "toBlockIndex": 16,
      "toPin": "Input"
      "toBlockIndex": 17,
      "toPin": "Input 1a"
      "toBlockIndex": 17,
      "toPin": "Input 1b"
      "toBlockIndex": 17,
      "toPin": "Input 2a"
      "toBlockIndex": 17,
      "toPin": "Input 2b"
      "fromBlockIndex": 12,
      "toBlockIndex": 18,
      "fromBlockIndex": 17,
      "toBlockIndex": 19,
      "toPin": "Input 1"
      "toBlockIndex": 19,
      "toPin": "Input 2"
As I mentioned to @Cybercow in a DM, please enter issues you find in SpinCAD at Github if you can.
I am not working on SpinCAD at the moment but this information would:
a) Give someone else who wants to contribute to the open source project (cough) something to do
b) Put everything in one place so if I ever do get the inclination to go back and look, then I can easily deal with several things at once.
c) Give others a heads up so they don't waste a ton of time.
Thanks,
DL
Thanks,
DL
Will do DL! Thanks.
JSON:
  "formatVersion": 1,
  "type": "patch",
  "comments": {
    "lines": [
      "Pot 1: Feedback",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 324,
      "y": 11,
      "name": "Input"
      "blockNum": 1,
      "x": 8,
      "y": 96,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 6,
      "y": 135,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 6,
      "y": 198,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 4,
      "x": 266,
      "y": 75,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 5,
      "x": 418,
      "y": 63,
      "name": "FB Out 1",
      "params": {
        "register": 33
      "blockNum": 6,
      "x": 66,
      "y": 97,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.15,
        "outHigh": 1.0
      "blockNum": 7,
      "x": 63,
      "y": 198,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.04,
        "outHigh": 0.8
      "blockNum": 8,
      "x": 158,
      "y": 97,
      "name": "Smoother",
      "params": {
        "filtReg": 37,
      "blockNum": 9,
      "x": 266,
      "y": 126,
      "params": {
        "inputGain": 1.0,
        "tap1Ratio": 0.125,
        "tap1Gain": 0.5,
        "tap2Ratio": 0.25,
        "tap2Gain": 0.5,
        "tap3Ratio": 0.375,
        "tap3Gain": 0.5,
        "tap4Ratio": 0.5,
        "tap4Gain": 0.5,
        "tap5Ratio": 0.625,
        "tap5Gain": 0.5,
        "tap6Ratio": 0.75,
        "tap7Ratio": 0.875,
        "tap7Gain": 0.5,
        "tap8Ratio": 1.0,
        "tap8Gain": 0.5,
        "mix1": 38,
        "mix2": 39,
        "max": 40,
        "tap8": 41
      "blockNum": 10,
      "x": 407,
      "y": 351,
      "name": "LPF 1P",
      "params": {
        "lpf1": 42
      "blockNum": 11,
      "x": 407,
      "y": 220,
      "params": {
        "feedback": 0.69,
        "damping": 0.7,
        "output1": 43,
        "filtReg": 44
      "blockNum": 12,
      "x": 407,
      "y": 403,
      "name": "FB In 1",
      "params": {
        "register": 33,
        "lGain": 1.0
      "blockNum": 13,
      "x": 242,
      "y": 238,
      "params": {
        "gain": 0.5,
        "feedback": 0.7,
        "damping": 0.5,
        "output1": 45,
        "filtReg": 46
      "blockNum": 14,
      "x": 407,
      "y": 273,
      "name": "LPF 1P",
      "params": {
        "lpf1": 47
      "blockNum": 15,
      "x": 242,
      "y": 289,
      "name": "LPF 1P",
      "params": {
        "freq": 0.15,
        "lpf1": 48
      "blockNum": 16,
      "x": 303,
      "y": 346,
      "params": {
        "gain1": 1.0,
        "gain4": 1.0,
        "output1": 49,
        "output2": 50
      "blockNum": 17,
      "x": 303,
      "y": 402,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "toBlockIndex": 4,
      "toPin": "Input 2"
      "toBlockIndex": 6,
      "toBlockIndex": 7,
      "toBlockIndex": 8,
      "toBlockIndex": 9,
      "toPin": "Input"
      "toBlockIndex": 9,
      "toPin": "Feedback"
      "toBlockIndex": 9,
      "toBlockIndex": 9,
      "toBlockIndex": 10,
      "toPin": "Input"
      "toBlockIndex": 11,
      "toPin": "Input"
      "toBlockIndex": 11,
      "toPin": "Feedback"
      "toBlockIndex": 12,
      "toBlockIndex": 13,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Feedback"
      "toBlockIndex": 14,
      "toPin": "Input"
      "toBlockIndex": 15,
      "toPin": "Input"
      "toBlockIndex": 16,
      "toPin": "Input 1a"
      "toBlockIndex": 16,
      "toPin": "Input 1b"
      "toBlockIndex": 16,
      "toPin": "Input 2a"
      "toBlockIndex": 16,
      "toPin": "Input 2b"
      "toBlockIndex": 17,
      "toPin": "Input 1"
      "toBlockIndex": 17,
      "toPin": "Input 2"
JSON:
  "formatVersion": 1,
  "type": "patch",
  "comments": {
    "lines": [
      "Pot 1: Feedback",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 340,
      "y": 4,
      "name": "Input"
      "blockNum": 1,
      "x": 8,
      "y": 116,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 8,
      "y": 155,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 11,
      "y": 319,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 4,
      "x": 266,
      "y": 75,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 5,
      "x": 388,
      "y": 74,
      "name": "FB Out 1",
      "params": {
        "register": 33
      "blockNum": 6,
      "x": 66,
      "y": 117,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.15,
        "outHigh": 1.0
      "blockNum": 7,
      "x": 68,
      "y": 319,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.04,
        "outHigh": 0.8
      "blockNum": 8,
      "x": 158,
      "y": 117,
      "name": "Smoother",
      "params": {
        "filtReg": 37,
      "blockNum": 9,
      "x": 266,
      "y": 146,
      "params": {
        "inputGain": 1.0,
        "tap1Ratio": 0.125,
        "tap1Gain": 0.5,
        "tap2Ratio": 0.25,
        "tap2Gain": 0.5,
        "tap3Ratio": 0.375,
        "tap3Gain": 0.5,
        "tap4Ratio": 0.5,
        "tap4Gain": 0.5,
        "tap5Ratio": 0.625,
        "tap5Gain": 0.5,
        "tap6Ratio": 0.75,
        "tap7Ratio": 0.875,
        "tap7Gain": 0.5,
        "tap8Ratio": 1.0,
        "tap8Gain": 0.5,
        "mix1": 38,
        "mix2": 39,
        "max": 40,
        "tap8": 41
      "blockNum": 10,
      "x": 226,
      "y": 209,
      "name": "Allpass",
      "params": {
        "gain": 0.5,
        "nAPs": 4.0,
        "ap1length": 125.0,
        "ap2length": 250.0,
        "ap3length": 750.0,
        "kiap": 0.5,
        "output1": 42
      "blockNum": 11,
      "x": 286,
      "y": 210,
      "name": "Allpass",
      "params": {
        "gain": 0.5,
        "nAPs": 4.0,
        "ap1length": 125.0,
        "ap2length": 250.0,
        "ap3length": 750.0,
        "kiap": 0.5,
        "output1": 43
      "blockNum": 12,
      "x": 395,
      "y": 208,
      "name": "LPF 1P",
      "params": {
        "lpf1": 44
      "blockNum": 13,
      "x": 227,
      "y": 346,
      "params": {
        "gain": 0.5,
        "feedback": 0.7,
        "damping": 0.5,
        "output1": 45,
        "filtReg": 46
      "blockNum": 14,
      "x": 402,
      "y": 321,
      "params": {
        "feedback": 0.69,
        "damping": 0.7,
        "output1": 47,
        "filtReg": 48
      "blockNum": 15,
      "x": 227,
      "y": 397,
      "name": "LPF 1P",
      "params": {
        "freq": 0.15,
        "lpf1": 49
      "blockNum": 16,
      "x": 402,
      "y": 374,
      "name": "LPF 1P",
      "params": {
        "lpf1": 50
      "blockNum": 17,
      "x": 322,
      "y": 467,
      "params": {
        "gain1": 1.0,
        "gain4": 1.0,
        "output1": 51,
        "output2": 52
      "blockNum": 18,
      "x": 395,
      "y": 260,
      "name": "FB In 1",
      "params": {
        "register": 33,
        "lGain": 1.0
      "blockNum": 19,
      "x": 322,
      "y": 523,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "toBlockIndex": 4,
      "toPin": "Input 2"
      "toBlockIndex": 6,
      "toBlockIndex": 7,
      "toBlockIndex": 8,
      "toBlockIndex": 9,
      "toPin": "Input"
      "toBlockIndex": 9,
      "toPin": "Feedback"
      "toBlockIndex": 9,
      "toBlockIndex": 9,
      "toBlockIndex": 10,
      "toPin": "Input"
      "toBlockIndex": 11,
      "toPin": "Input"
      "toBlockIndex": 12,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Feedback"
      "toBlockIndex": 14,
      "toPin": "Input"
      "toBlockIndex": 14,
      "toPin": "Feedback"
      "toBlockIndex": 15,
      "toPin": "Input"
      "toBlockIndex": 16,
      "toPin": "Input"
      "toBlockIndex": 17,
      "toPin": "Input 1a"
      "toBlockIndex": 17,
      "toPin": "Input 1b"
      "toBlockIndex": 17,
      "toPin": "Input 2a"
      "toBlockIndex": 17,
      "toPin": "Input 2b"
      "toBlockIndex": 18,
      "toBlockIndex": 19,
      "toPin": "Input 1"
      "toBlockIndex": 19,
      "toPin": "Input 2"
I like option 1 here. Option 2 also shows its exceeding max instructions and gets little wild.
Gotcha. And as a heads-up, the Instruction Line count bar at the bottom seems to be off. As I've been go thru these patch iterations and test the SpinASM code, the actual number of code lines is less than SpinCAD 99.1070 is reporting. I had one that read 135 but when converted to an actual ".spn" file, the code line count came in at 127. So just because SpinCAD reports >128 Instruction lines, doesn't mean it's unusable. And even when the actual code count is over 128, more often than not the patch can be optimized in SpinASM.
For these reverb patches, I've been building them first in an older version of SpinCAD (ver 99.1032), then transfer them to SpinCAD 99.1070 to make sure they pan-out and perform correctly. We'll get thru this. :cool:
Meanwhile, here are two candidates for R02 . . . .
Envelope Swell Ambient Reverb: Diffuse stereo reverb core paired with a slow envelope-controlled wet gain ramp for attack-free background pads.
R02_Stereo_Ambient_Swell_Reverb.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R02_Stereo_Ambient_Swell_Reverb.spcdj",
  "comments": {
    "fileName": "R02_Stereo_Ambient_Swell_Reverb.spcdj",
    "lines": [
      "Pot 0: Reverb",
      "Pot 1: Filter",
      "Pot 2: Envelope Follower",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 227,
      "y": 5,
      "name": "Input"
      "blockNum": 1,
      "x": 16,
      "y": 184,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 18,
      "y": 227,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 16,
      "y": 123,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 4,
      "x": 227,
      "y": 57,
      "params": {
        "gain1": 1.0,
        "gain2": 1.0,
        "output": 32
      "blockNum": 5,
      "x": 78,
      "y": 123,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.05,
        "outHigh": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.EnvelopeFollowerCADBlock",
      "blockNum": 6,
      "x": 175,
      "y": 123,
      "name": "Env Follower",
      "params": {
        "detectMode": 0,
        "gain": 2,
        "attackCoeff": 0.0016460396767089547,
        "releaseCoeff": 0.005566553699370536,
        "threshold": 0.1,
        "outputMin": 0.0,
        "outputMax": 1.0,
        "smoothCoeff": 2.0E-4
      "className": "com.holycityaudio.SpinCAD.CADBlocks.VolumeCADBlock",
      "blockNum": 7,
      "x": 278,
      "y": 123,
      "name": "Volume",
      "params": {
        "gain": 0.5011872336272722,
        "output": 37
      "blockNum": 8,
      "x": 86,
      "y": 184,
      "name": "Smoother",
      "params": {
        "filtReg": 39,
      "blockNum": 9,
      "x": 82,
      "y": 227,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.2,
        "outHigh": 1.0
      "className": "com.holycityaudio.SpinCAD.CADBlocks.reverbCADBlock",
      "blockNum": 10,
      "x": 278,
      "y": 183,
      "name": "Reverb",
      "params": {
        "LFOAIs0": true,
        "LFOBIs0": true,
        "LFOAIs1": false,
        "LFOBIs1": false,
        "gain": 0.5,
        "hpf4": 41,
        "lpf4": 42,
        "temp": 43,
        "rt": 44,
        "iapout": 45,
        "outputL": 46,
        "nAPs": 4.0,
        "kiap": 0.94,
        "nDLs": 3.0,
        "klap": 0.6,
        "kfl": 0.34262328449808055,
        "kfh": 0.011753443332901514,
        "lfoSelA": 0.0,
        "lfoSelB": 0.0,
        "rate1": 25.23,
        "rate2": 12.62,
        "hpf1": 43,
        "lpf1": 44,
        "hpf2": 47,
        "lpf2": 48,
        "hpf3": 49,
        "lpf3": 50,
        "outputR": 51
      "blockNum": 11,
      "x": 277,
      "y": 237,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toPin": "Input 1"
      "toBlockIndex": 4,
      "toPin": "Input 2"
      "toBlockIndex": 5,
      "toBlockIndex": 6,
      "toPin": "Audio Input 1"
      "toBlockIndex": 6,
      "toPin": "Threshold CV"
      "toBlockIndex": 7,
      "toPin": "Input"
      "fromPin": "CV Out",
      "toBlockIndex": 7,
      "toPin": "Volume"
      "toBlockIndex": 8,
      "toBlockIndex": 9,
      "toBlockIndex": 10,
      "toPin": "Input"
      "toBlockIndex": 10,
      "toPin": "Reverb_Time"
      "toBlockIndex": 10,
      "toPin": "Filter"
      "fromPin": "Output_Left",
      "toBlockIndex": 11,
      "toPin": "Input 1"
      "fromPin": "Output_Right",
      "toBlockIndex": 11,
      "toPin": "Input 2"
R02_Stereo_Ambient_Swell_Reverb_02.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R02_Stereo_Ambient_Swell_Reverb_02.spcdj",
  "comments": {
    "lines": [
      "Pot 0: Reverb",
      "Pot 1: Filter",
  "potValues": [
    80.0,
    60.0,
    21.0
  "blocks": [
      "blockNum": 0,
      "x": 227,
      "y": 5,
      "name": "Input"
      "blockNum": 1,
      "x": 16,
      "y": 184,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 2,
      "x": 18,
      "y": 227,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "blockNum": 3,
      "x": 16,
      "y": 123,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 4,
      "x": 78,
      "y": 123,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.13,
        "outHigh": 0.84
      "blockNum": 5,
      "x": 175,
      "y": 123,
      "params": {
        "detectMode": 0,
        "gain": 2,
        "threshold": 0.1,
        "outputMin": 0.0,
        "outputMax": 1.0,
      "blockNum": 6,
      "x": 278,
      "y": 123,
      "name": "Volume",
      "params": {
        "output": 36
      "blockNum": 7,
      "x": 86,
      "y": 184,
      "name": "Smoother",
      "params": {
        "filtReg": 38,
      "blockNum": 8,
      "x": 82,
      "y": 227,
      "params": {
        "inLow": 0.0,
        "inHigh": 1.0,
        "outLow": 0.2,
        "outHigh": 1.0
      "blockNum": 9,
      "x": 278,
      "y": 183,
      "name": "Reverb",
      "params": {
        "LFOAIs0": true,
        "LFOBIs0": true,
        "LFOAIs1": false,
        "LFOBIs1": false,
        "gain": 0.5,
        "hpf4": 40,
        "lpf4": 41,
        "temp": 42,
        "rt": 43,
        "iapout": 44,
        "outputL": 45,
        "nAPs": 4.0,
        "kiap": 0.94,
        "nDLs": 3.0,
        "klap": 0.6,
        "lfoSelA": 0.0,
        "lfoSelB": 0.0,
        "rate1": 20.94,
        "rate2": 12.62,
        "hpf1": 46,
        "lpf1": 47,
        "hpf2": 46,
        "lpf2": 47,
        "hpf3": 48,
        "lpf3": 49,
        "outputR": 50
      "blockNum": 10,
      "x": 278,
      "y": 238,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 4,
      "toBlockIndex": 5,
      "toBlockIndex": 5,
      "toBlockIndex": 6,
      "toPin": "Input"
      "toBlockIndex": 6,
      "toPin": "Volume"
      "toBlockIndex": 7,
      "toBlockIndex": 8,
      "toBlockIndex": 9,
      "toPin": "Input"
      "toBlockIndex": 9,
      "toBlockIndex": 9,
      "toPin": "Filter"
      "toBlockIndex": 10,
      "toPin": "Input 1"
      "toBlockIndex": 10,
      "toPin": "Input 2"
I like the first iteration here. This was a closer one. They both sound useful.
Noted and recorded.
Here's candidate R03 . . . . Dense stereo reverb tank with multiple out-of-phase LFOs modulating internal delay taps to simulate ensemble movement.
R03_Stereo_Shimmer_Reverb_04b.spcdj
JSON:
  "formatVersion": 1,
  "type": "patch",
  "patchFileName": "R03_Stereo_Shimmer_Reverb_04b.spcdj",
  "comments": {
    "fileName": "R03_Stereo_Shimmer_Reverb_04b.spcdj",
    "lines": [
      "Pot 1: Shimmer",
      "Pot 2: Filter (LP = 1548Hz; HP = 52Hz)",
      "R03_Stereo_Shimmer_Reverb_04b from R03_Stereo_Shimmer_Reverb_04.spcd",
  "potValues": [
    0.0,
    0.0,
    0.0
  "blocks": [
      "blockNum": 0,
      "x": 202,
      "y": 15,
      "name": "Input"
      "blockNum": 1,
      "x": 268,
      "y": 24,
      "name": "FB Out 1",
      "params": {
        "register": 32
      "blockNum": 2,
      "x": 24,
      "y": 102,
      "name": "Pot 1",
      "params": {
        "speedup": false,
        "potRegister": 17
      "className": "com.holycityaudio.SpinCAD.CADBlocks.Mixer_3_to_1CADBlock",
      "blockNum": 3,
      "x": 201,
      "y": 81,
      "name": "Mixer 3:1",
      "params": {
        "gain1": 0.7079457843841379,
        "gain2": 0.7079457843841379,
        "gain3": 0.5623413251903491,
        "output": 33
      "blockNum": 4,
      "x": 22,
      "y": 147,
      "name": "Pot 0",
      "params": {
        "speedup": false,
        "potRegister": 16
      "blockNum": 5,
      "x": 86,
      "y": 148,
      "name": "Smoother",
      "params": {
        "filtReg": 35,
        "filt": 1.5E-4
      "blockNum": 6,
      "x": 21,
      "y": 228,
      "name": "Pot 2",
      "params": {
        "speedup": false,
        "potRegister": 18
      "blockNum": 7,
      "x": 201,
      "y": 146,
      "name": "Reverb",
      "params": {
        "LFOAIs0": true,
        "LFOBIs0": true,
        "LFOAIs1": false,
        "LFOBIs1": false,
        "gain": 0.5,
        "hpf4": 36,
        "lpf4": 37,
        "temp": 38,
        "rt": 39,
        "iapout": 40,
        "outputL": 41,
        "nAPs": 4.0,
        "kiap": 0.5,
        "nDLs": 3.0,
        "klap": 0.6,
        "kfl": 0.2569425140260494,
        "kfh": 0.01,
        "lfoSelA": 0.0,
        "lfoSelB": 0.0,
        "rate1": 20.0,
        "rate2": 20.0,
        "hpf1": 41,
        "lpf1": 42,
        "hpf2": 42,
        "lpf2": 43,
        "hpf3": 44,
        "lpf3": 45,
        "outputR": 46
      "className": "com.holycityaudio.SpinCAD.CADBlocks.PitchShiftFixedCADBlock",
      "blockNum": 8,
      "x": 131,
      "y": 222,
      "name": "Pitch Shift 0",
      "params": {
        "freq": 12,
        "cents": 0,
        "amp": 2048,
        "lfoSel": 0
      "blockNum": 9,
      "x": 131,
      "y": 274,
      "name": "LPF 1P",
      "params": {
        "freq": 0.1819111947482558,
        "lpf1": 52
      "className": "com.holycityaudio.SpinCAD.CADBlocks.HPF_RDFXCADBlock",
      "blockNum": 10,
      "x": 131,
      "y": 326,
      "name": "HPF 1P",
      "params": {
        "freq": 0.015,
        "output": 53,
        "lpf1": 54
      "blockNum": 11,
      "x": 131,
      "y": 379,
      "name": "FB In 1",
      "params": {
        "register": 32,
        "lGain": 0.8
      "className": "com.holycityaudio.SpinCAD.CADBlocks.TripleTapCADBlock",
      "blockNum": 12,
      "x": 244,
      "y": 223,
      "name": "ThreeTap",
      "params": {
        "inputGain": 1.0,
        "fbkGain": 0.5,
        "delayLength": 6906.0,
        "tap1Ratio": 1.0,
        "tap2Ratio": 1.0,
        "tap3Ratio": 1.0,
        "subdivision": 0.0,
        "output1": 55,
        "output2": 0,
        "output3": 0
      "blockNum": 13,
      "x": 200,
      "y": 464,
      "name": "Output",
      "params": {
        "mono": false,
        "offset0": false,
        "gain1": 1.0,
        "gain2": 1.0
  "connections": [
      "toBlockIndex": 3,
      "toPin": "Input 1"
      "toBlockIndex": 3,
      "toPin": "Input 2"
      "toBlockIndex": 3,
      "toPin": "Input 3"
      "toBlockIndex": 3,
      "toPin": "Level 3"
      "toBlockIndex": 5,
      "toBlockIndex": 7,
      "toPin": "Input"
      "toBlockIndex": 7,
      "toBlockIndex": 7,
      "toPin": "Filter"
      "toBlockIndex": 8,
      "toPin": "Audio In"
      "fromPin": "Pitch Out",
      "toBlockIndex": 9,
      "toPin": "Input"
      "toBlockIndex": 10,
      "toPin": "Input"
      "toBlockIndex": 11,
      "toBlockIndex": 12,
      "toPin": "Input"
      "toBlockIndex": 13,
      "toPin": "Input 1"
      "fromPin": "Tap 1 Out",
      "toBlockIndex": 13,
      "toPin": "Input 2"
