Harry Klippton
Great choiceThanks, all. I am going to get the CS12 TRUETONE unit.
Chuck D. - This room is all LED light, no flourescents, no fans. Mostly I use all humbuckers or stacked singles, I almost never use true single coils (metalhead). I have to spin my chair to face a certain wall to get rid of noise and if I swing into certain "hot spots" the noise gets super insane. I may consider running a dedicated 30A 120V circuit to my mancave. I have a cinder block home and my sub panel is 50' away. Could do it with external conduit and just run a dedi circuit instead of having my stuff share the line with whatever the hell else is on the ckt.Single-coil pickups? If so, it's magnetic pickup, most likely from your amp. However, anything powered by the AC line could be the culprit, including fluorescent lights, fans, etc.
I'm contemplating picking up a generator and an isolator from the gigrig then picking up more bits every few months after that. It does look like an excellent adaptable system.If money was no object I would 100% go the gigrig route. For my set up i think it would have cost £350+ so I couldn’t condone that for just being a bedroom playa.
Good call. I know it stings a little to spend so much on a power supply, but this is a pretty clear "Buy nice or buy twice" situation.Thanks, all. I am going to get the CS12 TRUETONE unit.
^ +1Good call. I know it stings a little to spend so much on a power supply, but this is a pretty clear "Buy nice or buy twice" situation.
You also could just build a power supply...
This one can be isolated and not isolated. I don't know where you would get the mini isolated transformers though. Might be able to email the site for the specs. I know you already bought one, but just posting this so people can build one if they want. They are ridiculously simple, that's why truetone can survive as a business selling power supplies. This one is not isolated. Take a look at the gunshots though. It is probably child's play for all the experienced members on the forum. The transformer is cheap too.
The thing is, the truly isolated supplies have a transformer, rectifier, filter and regulator for each output.Wouldn’t be 120vac on the veroboard just on the transformer primary, secondary is attached to the veroboard which should only be something like 12vac which then gets rectified, filtered, and regulated.
I briefly looked into Rg’s spider power supply diy, real cool but these days with the prevalence of cheap, small, isolated supplies there isn’t any cost or size savings there. 10 or 15 years ago though, it may well have been the best option for someone with the skills
That’s what I have on my board, I use an older donner for my bench or if I want to hook up 20 pedals at once lol.Thanks, all. I am going to get the CS12 TRUETONE unit.
Strymon made me realize that the effects loop in one of my amps was creating a ground loop tooI’ve never found isolation to be an issue until I purchased my Strymon units. Digital pedals really need isolated taps.
My $35 otraki supplies are great for everything else but my digital pedals definitely need to be segregated.
If you're not going to do that, then all of your DIY hours are going to result in something just as good or worse than the $35 Donner unit.
