Informant overdrive - no sound when disengaged
Matmos
Hello, I've just built the informant overdrive and it sounds great! But when I disengage the pedal no sound is passing though... I followed the instruction for true bypass wiring. What's the problem? 20201203_175119.jpg
I think your Input & or Output jack Blue wire connections are touching the corner posts on your enclosure.
Blow up your Picture you posted & you will see how close the Input connection is/was!
Rotate so they are clear & you should be OK.
That's probably a noob mistake ah ah ah. Thank you so much, I changed the jacks position and put some electrical tape and now it works fine!
