"Insufficient Drill Quantity." error???
Preverb
I keep getting an error with one the custom drill template for the clandestine preamp (template was provided from here). It says "Insufficient Drill Quantity." when I try to submit it. The pedal only requires 1 vol knob and 1 switch + 1 footswitch. Is that the issue? Any suggestions?
When are you getting the error? When you're designing/saving the template or when you're trying to assign the saved template to your order?
Design is no problem. It is when I attempt to assign the saved template to the order. I had purchased a 125b to go with it so have no idea why I am getting the error. Starting to wonder if it is a sign. I had been considering to combining the Magnetron and Clandestine in one box.
Are you using chrome? I get errors with the tool in Safari sometimes.
Firefox currently. I could probably try resubmitting with another browser.
I had a look at your template. Did you use this for the Clandestine preamp? I noticed that there is one big difference on the top side (A). You have one value that is 12.1, whereas mine has it at 27.305. I think that is for the LED which would probably line up where the Clandestine LED is. The only other difference is the right hole on the top which is 1 mm smaller since it will have a switch instead of potentiometer.
Just for the heck of it, try rounding -27.305 to -27.3
I changed the value to 1 decimal place as suggested and still end up with the same error when submitting it. I double checked the order thinking maybe I had maybe ordered the pre-drilled enclosure by mistake but that wasn't it. Also double checked I ordered the 125b drill service instead of a different sized enclosure.
I guess at this point, I will have to wait for Hugo to get back to me.
Oh sorry no this is just the generic 2 knob layout, I didn't catch the differences before replying.
