HI, I want to get a MXR 10 band EQ, but I dont want the power input on top and instead the left side, is it possible to detach from the PC Board and connect something else to create a input on the left side of the box?
While you'll not be able to re-mount that DC jack elsewhere on the PCB, if there is sufficient space to insert a new DC jack (like the one in the attached image), the old one can be removed and the new one wired in its place.
yeah so what you recommend, detaching the old one, wiring anew one with cable two+ inches and just screw it like this, do you know if there are videos of doing this?
Cheers
