S Squiblert New member Aug 28, 2025 #1 I'm looking for a drill template for Tayda drill service for the Rangefinder. Thanks!
J jcpst Well-known member Aug 28, 2025 #2 Hey @Robert , is the rangefinder the same as if you only used the center knobs on a 6-knob template? This is unverified, you might need to adjust holes for LED and rotary switch. Tayda Electronics Drill Tayda Electronics Drill Designer for custom enclosures. drill.taydakits.com
S Squiblert New member Aug 31, 2025 #3 jcpst said: Hey @Robert , is the rangefinder the same as if you only used the center knobs on a 6-knob template? This is unverified, you might need to adjust holes for LED and rotary switch. Tayda Electronics Drill Tayda Electronics Drill Designer for custom enclosures. drill.taydakits.com Click to expand... Thanks for responding. Still not verified yet though… that’s unfortunate since I need to order enclosures now.
spi Well-known member Aug 31, 2025 #4 It should work. From the printed drill templates you can see the holes are aligned with other templates (plus Robert is very consistent). @Squiblert if you have doubts, print the drill template at 100% size, and measure the location of the holes to verify.
J jcpst Well-known member Aug 31, 2025 #5 I took another look- if you use the the mini 1p8t rotary that mounts on the board, that hole size (7.2mm) should be fine. So then the only decision to make is what size you want the LED hole.
