Caldo71
I think the answer is “NO”, but I wanted to ask just in case.
An example to make my question more clear:
- The pitch between pads for the potentiometers on a PedalPCB build is 5mm.
- I’m hoping to turn a lot of those tone controls etc into tiny internal trim pots instead.
- Those trimmer resistors have a much smaller pitch.
- I could make those connections happen with little solid core jumper wires and some needle nose plier finegeling, but it would feel a bit sloppy and less solid to me…I prefer a clean build.
- So the “dream solution” would be some kind of socket or small conversion board to take the pitch way down.
