Hi there,
I got the Low Tide Modulator pcb along with some other projects. While I could finish the other effects just fine, I came across a problem with the Low Tide. I hope you can help me.
So the issue at hand is that the polarity protection diode (D3) gets fried whenever I power up the circuit.
After the first time, I removed all IC’s and transistors, because the board got really hot. But even without transistors and IC’s connected, the D3 gets fried immediately. I even tried to use a N4001 diode instead of the BAT48. The diode remains to get fried and it gets really hot.
I switched out the DC socket, double and triple checked the polarity of the wiring and the DC plug (center negative) and it’s all correct. I even let a friend look over the build, just to make sure I didn’t miss anything.
Do you have any idea, what the problem might be?
I would really appreciate your support on this.
Thanks
Thanks
