@Chuck D. Bones feel free to remove this if you find it to be OT.
How can I measure p-channel jfets to check if they're in spec?
A few J113 transistors selected for Q1 in the Viceroy
IDSS in mA
VP in V
Breadboard CCTT Delta between Breadboard & CCTT
IDSS VP IDSS VP IDSS VP
Q1 6.86 -1.04 7.2 -0,945 0.34 0.095
Q2 7.40 -1.07 7.8 -0.985 0.40 0.085
Q3 7.18 -1.07 7.6 -0.978 0.42 0.092
Q4 7.34 -1.08 7.8 -0.990 0.46 0.090
Q5 7.11 -1.05 7.6 -0.965 0.49 0.085
Parameters are much closer to 5457 than J201, so they may not work well in every circuit as a sub for J201.Hey does anybody use J202 instead of J201 in pedals?
I have some from DigiKey, yes. Also I've been trying out a preamp-style circuit made via JLCPCB using the surface-mount variety. I originally did the circuit with J201 but since I had a higher voltage (28V), and the higher Vp of the J202 would allow me to not have a voltage divider right at the input, I used those instead of J201. I had to bias differently, and the attenuation pads I had to adjust (a couple of gain stages and a tone stack), but what I found is that, perhaps because the parts in the same reel maybe came from the same wafer section, the Idss and Vp were a lot closer. I used the Fetzer-modified circuit for the stages, and found that pretty much the same standard Rd and Rs values could be used across all of these on each one I made (JLCPCB has a minimum of 5) on each board (I didn't populate Rd and Rs and put them in after measuring each stage).There is some overlap in the specs of J201 & J202. So it's possible to sub the J202 in some circuits. J201s have a very broad Vp range. Some will not work in certain circuits that call for J201. The easiest way to know if a particular JFET will work in a given circuit is to try it.
I have a question for you: do you have any J202s?
