Chuck D. Bones
Circuit Wizard
Follow-up on the transistor tester...
It measures germanium transistors correctly - it accounts for leakage (Iceo) when measuring and calculating current gain (hFE). I checked a few Ge transistors using the tester and the "Bare Bones" method and they correlate. To quote Steve Daniels of Small Bear Electronics: "The temperature sensitivity of older germanium transistors has to be seen to be believed..." This is no exaggeration. Whatever method you use for measuring Ge transistors, they have to temperature stabilize before you can get a useful reading. The heat from your fingers can drive the leakage up 4x or more with some transistors. It can take several minutes for the device to cool down and stabilize after handling.
The diode test current is fairly high, causing some diodes (the ones with higher resistance) to read an abnormally high Vf. Those I test with a DMM.
