Hello,
I have just built a King Midas overdrive. The pedal works in bypass mode and the clean signal has no issue. But when the pedal is engaged I do get the led for power. The issue is that their is a constant loud hum and no guitar signal seems to be making it through the pedal. This hum is not affected by turning the pots it’s the same constant hum no matter what. Can someone help before I go nuts.
Thank you all.
Thank you all.
