Absolutely. If you have multiples of the 1.5nf and if you have a DMM that can measure capacitance, you will likely find one that edges towards 2nf. more than likely you won’t hear a huge difference
Yup. They are pretty common fare for when you want to play around with different values. Just use a sharp blade (xacto or a razor blade) to cut off however many you need to span the space. You can do singles, or cut 4 and either clip the legs off the middle 2 or find a way to push the middle 2 sockets out.
You can put two 3.9s together parallel, two 1.5a together parallel, and then put those two together in series and you’ll have about 2.2nF. And no room to put that monstrosity, lol.
