R RobertJay Member Mar 16, 2021 #1 So what's the deal with the drill template for this one? The double 100k Pot put the location of the needed hole off. This template has them lined up next to each other. IS it me? The instructions? My pots being manufactured a different way?
Robert Reverse Engineer Mar 16, 2021 #2 Where'd you get your dual pot? Someone else had this problem a while back, the pots should be aligned with the drill template.
finebyfine Well-known member Mar 16, 2021 #3 This alpha pot from Tayda worked perfectly for me, fit like any other 3 knob board 100K OHM Linear Dual Taper Potentiometer PCB Mount Round Shaft Dia: 6.35mm ALPHA - Get It Fast - Same Day Shipping www.taydaelectronics.com
Barry Well-known member Mar 16, 2021 #4 I got some dual pots a while back that don't line up, anybody need dual pots cheap?
