faramir
Seems like a Klon(e) is an obligatory build, so here's my Kliche Mini SE! Didn't change any components pretty much just basic stuff from Tayda and Stompboxparts.
The case is dark metallic gold with UV printing featuring everyone's favorite human animal hybrid: Manbearpig. Might have bolded the text if I was doing it again.
Only issue I encountered is that I reused the holes from another build on my drill template. Unfortunately the jack holes need to be slightly lower to accommodate the PCB in this one. I just used a dremel to shift them down a bit. I also lifted a pad on the switch board but managed to fix that.
Need to play it some more but the sound is great. Almost no noise. Brighter than I was expecting. Very classic.
