Kliche Mini SE no crunchy
Jmarqusee
Hey all,
Wondering if by this image yall can help me sort out where the gain is on my pedal. Per an earlier thread by @NickC , my pedal isn’t generating any distortion/clipping, but rather gets more compressed a little quieter when I turn the gain up.
Ic Values:
IC1 : 3.57, 3.57, 2.79, 0, 3.57, 3.57, 3.57, 7.14
IC2: 3.57, 3.57, 3.57, -6.68, 3.75, 3.75, 3.57, 12.4,
IC3: 7.13, 3.64, 0, -3.29, -6.67, 2.91, 4.42, 7.13
One last note: I reflowed everything so it may look a little glooby. Don’t shame a lowly novice ….
Thanks everyone !
Use your meter to verify the gain knob is working correctly. Check for resistance between lugs 1 and 3 and make sure it matches the pot's value. Then check for resistance between lugs 1 and 2 and then 2 and 3. These two measurements should add up to what you got between lugs 1 and 3, and they should change as you turn the knob.
The gain control is a dual gang so do this for both sets of lugs. Since you have an issue as you turn the gain knob, let's check that first
