I want to build the Mini, but it's not in stock. The Clean appears to me (verified moron) to be the same board with some different values. Could I buy the clean and use the build guide from the mini?
I would like to know the answer to this as well. I noticed there were two resistor differences and someone pointed out on another thread one or two differences in cap values.
I was wondering if it would be possible to put the two resistor on a DPDT switch in order to have a switchable stock setting, and boost mode. Or are there differences in the wiring (not just the component values) that make the boost circuit unique from the stock klon?
From a quick glance, the layouts of the physical parts appear to be the same, and the schematics look to be the same as well, but there are some very clear differences in the routing of the traces in the thumbnails between the two boards that suggest that I might have overlooked a difference in the schematic (had to go back and forth comparing them since I’m on my phone— didn’t look at them side by side at all)
