Kliche Overdrive Issues?
Cagno
Currently having issues with my newly built Kliche Overdrive. When the pedal is disengaged it bypasses signal, but it still seems as if its going through a clipping circuit of some sort. And as soon as you engage the pedal it becomes a turbo fuzz face at 100% gain. Not sure what to look for or turn too.
I've attached some pictures, any help is appreciated.
Start by checking / double checking all of your resistor values.
It sounds like a gain stage is running too hot, that's probably what you're hearing in bypass as well.
