Kliche Overdrive with 6 pin footswitch
claudio
I put together a Kliche Overdrive and I have a 6 pin footswitch. The build documentation shows wiring with the footswitch board and I see 6 connections are needed, so I d assume that is doable. I also saw in another thread that it’s possible but the led wouldn’t work (it was a general question about 6 pin footswitches), but I believe this is not applicable to the Kliche Overdrive as the led is on the main pcb.
How would I go about finding out how to wire it?
This Reddit post shows a direct wiring without the footswitch board that’s using only 6 pins, so I’d assume (without necessity to be right…) I can go about it by just assuming the central unused pins column is what I am missing?
So if it’s a latching dpdt switch you should be able to wiring like this, ignoring the middle row.
A 3pdt is three single pole dual throw switches in one one housing
So a dpdt is two single pole dual throw switches in one housing.
