Well fortunately the audio is working. The led circuit is only a few components / connections, so it shouldn’t be hard to find the issue. Follow the schematic to see how it works.
Confirm the orientation of the LED is correct. Check the stomp switch wiring. Use a multimeter to verify that S6 connects to ground when the pedal is activated. Check for voltage on both side of the resistor (R-27: 3k9) and the anode of the LED.
