Hello all,
After 2 days of trying to find the problem, I have nothing, I am desperate and really need your help. This is a PCB Guitar Mania's Kot which there is a 18v charge pump. Both switches work fine with leds, there is a sound in bypass but there is no sound when I engaged, both channels have same problems.
Result of my diagnostic:
Here is the schematic:
Photos inside:
Cheers
- I used audio probe and find that there is a sound on IC1's pin 3 and not pin 3. And checked the other pins. I found that I have voltage problem.
- When I remove IC's and read the voltage:
Pin 4 = 0 v as expected
Pin 5 = 0 v it suppose to be around 9v as Vb
Pin 8 = 0 v it suppose to be around 18v
- When I check the power section I have 17.39v from output of D15
- If I remove R13's one leg I have 17.39v in Pin 8 of IC1
- I have already replaced almost everything on pover section, R12, R13 and C10 but result is same.
- When I check the continuity from Pin 5 and 8 to ground, they seem fine nothing to the ground.
- I have already replaced IC3 but the result is same
Photos inside:
Cheers
