Latching bypass board... I have questions.
Paradox916
So If I understand this correctly,( please someone tell me if I do or don’t) with the new latching bypass relay you can put that in a OD or boost pedal and be able to control amp channel switching simultaneously with the pedal it’s installed in? Just like the fortin 33?
No, that's not what it does... but I do need to work one of those up.
The "channel switching" mode of the Intelligent Relay Bypass allows you to build a pedal with multiple effects in one box and instantaneously switch between them by stepping on each effects corresponding footswitch.
For example, if you build a pedal with an Overdrive and a Fuzz you can step on the Fuzz footswitch; the Fuzz will be activated and the Overdrive will be deactivated with a single step. Pressing the active footswitch again will bypass the entire pedal.
Wow I was way off the mark. Sorry for letting the dumb out. I’m still really new to this. But
If you were to make an add on utility switch board that slaves the channel latching on an amp (If that makers sense) That would be pretty awesome. I for one would find that very useful especially in an boost, OD, or even an A/B box( I think that would be super trick). Hopefully my noob rambling doesn’t annoy everyone too much.
