Big Cheese
Having some issues test fitting some components before starting my build. Using alpha 16mm right angle pcb mounted pots, and while test fitting them into the enclosure i've run into some issues with the fitment. I have followed the drilling template, and have completed quiet a few builds in the last couple years however this is my first time running into this issue. The legs on the Pots seem to be too long to the point where it is not sitting flush with the pot above.
This is quiet frustrating, as the C25k pot was a PITA to source. as I said above, I have followed the drilling template to a T. The legs are also preventing the SPDT ON-ON switch for depth from sitting flush and makes contact with said legs. Some electrical tape will help preventing a short, but Im at a standstill with the non fitting pots. I've only seen one other thread about this pedal, with no one else running into this issue. Any suggestions?
