The treble was the only lug pot, the rest are pcb mount. It was making contact with the toggle switch. A little black tape fixed that but I'm still stuck on why the bass isn't working.
Post some pics of both sides of the board. This is pretty much a Marshall tone stack, so no voltage readings are necessary here. You probably have a bad solder joint or C14 might not be the correct value.
Thanks! I'll check that out. It was a kit from Musikding so it's more likely a bad solder joint. The bass pot measures at 500k for some reason but it is a 1M.
