DGWVI
- Build Rating
- 5.00 star(s)
A 70s whoosh and wobble box with built in Overdrive. Not the most intuitive Phaser I've built/ played, but it does offer up a ton of sounds. It can do some vibey throbs, all the way up into flanger impersonation. The OD has a nice range from clean to heavy.
No mods to this one, as it already has so much going on.
I definitely need to spend some more time with this one- I really like the sounds it makes, but the Range and Sweep Mod controls bring in some variability that isn't present on any of the other phasers I've used. HUGE range from each of the pots, and their interactivity will take some getting used to
Fairly large build, but easy enough to assemble and calibrate. I wouldn't recommend this as someone's first Phaser, but definitely would for those looking for something little different than can span the range of Univibe to faux-flanger
