I incorporated the Basic Relay Bypass system into an overdrive/eq pedal I designed, but I'm encountering a small issue. The pedal sounds great, there's no cutting in and out, or any obvious voltage starvation, but for some reason when the pedal is on, the indicator LED is flashing instead of being static. I added a trimpot to adjust the brightness of the LED, and while it does adjust the brightness, it also adjusts the speed of the flashing (but the range is pretty small).
Circuit Schematic:
PCB design:
Voltages:
NE555
Pin 1: 0v
Pin 2: 2.54v
Pin 3: 3.67v
Pin 4: 5.10v
Pin 5: 3.39v
Pin 6: 2.54v
Pin 7: 0-0.05v (varies)
Pin 8: 5.1v
Voltage regulator (LM78L05)
Output: 5.10v
Ground: 0.0v
Input: 8.96v
Q4 (2n5088)
Emitter: 0.0v
Base: 0.65v
Collector: 0.0v-0.09v (goes up and down, and seems to vary based on trimpot position)
Circuit Schematic:
PCB design:
Voltages:
NE555
Pin 1: 0v
Pin 2: 2.54v
Pin 3: 3.67v
Pin 4: 5.10v
Pin 5: 3.39v
Pin 6: 2.54v
Pin 8: 5.1v
Output: 5.10v
Ground: 0.0v
Input: 8.96v
Q4 (2n5088)
Emitter: 0.0v
Base: 0.65v
