gtfields13
I finished a rat clone in July (Build Report) using an LM308N DIP purchased from Jameco (Link).Has anybody recently purchased any legit lm308n chips? If so from where ? I want a few not just for the rat but a couple other builds I'd like to try. Took 2 gambles on it so far First Ali express ( I knew it was a crap shoot gamble from the start) and 1 from good ol Flea bay also a no go.. Both were a few years back so I imagine the supply is much less.
I never really thought about whether this was real or not, so I went and pulled the chip. Using the test posted by @Chuck D. Bones, I found the supply current for my chip is 740-750 µA, which looks to be at the high end, but within spec for this chip. (Assuming that measuring the current into the LM308N at pin 7 is the supply current). This is lower than the supply current for any other chip that I had readily at hand to check (including OP07D and LT1115).
This chip is pictured below, it is laser-marked, not printed, which I believe (google search) was in use by National by 1993 (when the code suggests the chip was made, if I interpret it correctly).
So, while not a low current chip, the data suggests this Jameco purchase was authentic.
