Lemon Rockerverb- no sound when engaged
megatrav
I've been working on this build from guitar pcb mania.
I have bypassed sound. No sound when engaged but I do have an LED.
I took some shots of the board and I can't spot any bad connections so I think I might have the switch Ground and Control backwards. The PCB only says CNTRL.
I haven't tried swapping them yet but I wanted to post here to see if anyone might catch something else I may have done wrong.
D8E1A375-3995-4E14-B3DE-0B7D22196D96.jpeg 1356B69E-4BEF-4727-9D34-25382E24CF51.jpeg CF32E9F3-AD5D-4D76-9638-E0652C9C6873.jpeg 7C420E8D-B9B7-4F23-987C-2DAC7BFF7725.jpeg
Thanks!
I believe so since I am able to get sound from my guitar when bypassed
Just confirming, Your guitar lead is plugged into the Input jack of the Pedal & Output Jack of pedal is going to Amp.
I have accidently plugged them in the wrong way more than once when the Pedal or Circuit is upside down on the Floor !!!
Have you fixed the Continuity issue with Q2 Blue Pads?
I did. All the jfets now have continuity. Unfortunately I still don't have any sound
when the pedal is engaged.
